RA2 5.0 Radio
Status
Not open for further replies.
JRG18
Northern VA
6.7 CTD
This came out of my 2015 when I did the RA4 swap. Only thing I don't know is what the security code is for it.
$225 shipped.
R.L.K.
Bristol , Tn.
No worries if the buyer takes the radio to his local dealer , they can give them the security code in less than 3 min.
noclass
They will need the vin from the truck it came from to get the code
JRG18
JRG18
Northern VA
6.7 CTD
It's out of my truck and don't mind giving up the VIN but If it's that easy then I will send an email to my service manager and ask for it.
R.L.K.
Bristol , Tn.
It is that easy , I installed 2e diff RA2 s in my truck before I upgraded to the RA4 8.4NA , niether of the RA2 radios required an anti-theft code for me .....
JRG18
JRG18
Northern VA
6.7 CTD
Price not firm. Gimme an offer.
Pez68
Did you get the security code?
homebrew
Cummins
Does this require anything else to make the compass work? A Bluetooth mirror would be required as well correct?
R.L.K.
Bristol , Tn.
Requires a compass module , a 3 wire harness and a dealer flashed code CV2.
Hope this helps
JRG18
JRG18
Northern VA
6.7 CTD
Bought above radio. You don't know part numbers to madule and harness do you. Can you find them on ebay.
I don't think there are any modules or harnesses necessary to go from RA1 to RA2 5.0. Should just be plug and play. I'll send you my VIN just in case you need it for the security code but as others have stated, the 5.0 radios under most circumstances don't ask for it.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
As mentioned it's plug n play as is but if you want full functionality, you may want to add the Ra2 mirror w/mics, the VR/phone button and maybe the steering wheel audio controls if you haven't already.
- RA2 style Manual Dim Mirror w/mics: - 68102484AA (Recommended)
. . . (Man. Mirror Mount Covers if Needed: Upper - 1ZA38DX9AA and Lower - 1YW11DX9AA )
- Mirror Header harness (Standard): - 68207372AB
- VR/Phone Button (for steering wheel) - 56054449AA
DIY: 2013-2014 OEM Steering Wheel Audio Control Install
2013-2016 VR/Phone button Assy (56054449AA)
$40
Other things you might like...
Installing OEM Backup Cam
Pay attention to the links in post 10
Sent from my non-flammable Galaxy S7!
Status
