jstargell
My radio just stopped working and the dome light will not come on. The bulbs are good and I have checked all fuses, followed the ground wires and all are attached. Has anyone else had a problem like this?
Howd you check the fuses? Sometimes they can break in hair fractures so you can't see its broken. Check the ground wires again, make sure theres good wire in the sleeves! You'd be surprised what can go on inside them corrosion wise. Really sounds like a bad ground or fuse to me.
What about the IOD fuse? I forget what all that guy controls...
