Radio installation leads to dash failure
nitto
Lancaster Pa
1999 Dodge 2500
v10
well about 5 months ago I attempted to wire up a new headunit and it ended up that the radio didnt work so I went for a good bit without one and realized thaat my power mirrors and interior lights stopped working after that, I thought nothing of it because I figured maybe some crazy way they were wired in with the radio (which would be dumb)
SO today I bought a new headunit and installed it and everything was good, I noticed my mirrors and lights interior lights still do not work so I checked my fuses and they were all good, Then I was driving and realized my dash gauges would work right when I Started my truck but right when I would go to drive it they stopped working.. SO they work when I start it but as soon as I drive the stop or after sitting at idle for more than a minute or 2.
ever since radio installed
mirror and interior lights dont work
and now my dash cluster only works for a few minutes
someone please help, I havent checked my fuses after I noticed the dash thing but I figured they wouldnt be blown if they work for a couple minutes. my milleage counter doesnt even work so its hard to tell how much I can go on a tank of gas lol :shakehead:
WhiteExpress
Midland, TX
Oh my! What a mess.
Start with the basics. Remove anything you've done.
Pull the radio out. I hope you used a harness, even if you didn't, just unplug it from the back of the head unit itself. Then start diagnosis.
Get yourself a Haynes manual for the truck, they have a wiring diagram.
Start following the wires back to the common source.
I would open up the bulkhead connector that is behind the driver's wheel well, clean the contacts and slather with dielectric. Always a good idea on a Gen II period.
Electrical problems are VERY difficult to diagnose over a medium like the internets unfortunately.
nitto
nitto
Lancaster Pa
1999 Dodge 2500
v10
I have a haynes manual and I am already pulling my hair out, Im going to check the fuses and take the radio back out after work
