Radio not working
Chris Sorrels
Louisiana
5.7L Hemi v-8
I have a 2020 5.7L Limitied edition Dodge Ram truck. So far I have loved it. This morning I got in and started it like I do every morning and went to work. Only problem was that I could not get any sound to work in my vehicle. I have Sirius XM radio but it continues to cycle as if it is trying to load. So I then attempted to turn on the FM radio. Everything worked as normal on my big screen but the sound did not. I then plugged in my phone through USB connection and started Apple/Car Play. Screen showed music I was attempting to play and even showed it playing but sound would not come on(stuck at 25). Please help.
Kellen
Atlanta
5.7 ETorque
I just had this happen for the first time 2 weeks ago, turned the truck on and there was no volume indicator on the screen when adjusting, no sound either. Music was playing like normal but I had no audio. Press the SOS button by the roof, I did that and it started working like magic. I researched that from some old threads and it did the trick.
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
Happens to me every now and then and it usually comes back after a few key cycles (the truck has to sit for a bit for the system to reboot instead of restart).
You can try to do a soft reset to see if that helps: push and hold the 2 outside buttons/knobs for about 30 seconds and the Infotainment should reboot.
njsportsman62
All I have to say on this issue Chris is I LOVE your flag. TRUMP - DESANTIS 2024
Cobr96
Same issue here, anyone find a permanent fix? If it's just pulling the fuse, it's that under the driver side dash? Have to remove the panel under the steering column to access?
