Ram 14 Crew 2wd MCG 2/4 drop #44052 questions
brad65ford
Whats shaken guys, ive been reading and searching the forums/threads here but haven't posted yet. Looks like a bunch of cool guys with similar interests as my own.
First off I love my Ram, been wanting one since my buddys 2011 he had. Always loved the lowered look especially on the newest gen 4's.
Needless to say I started with the cutting the rear coils to level her and that's all it took for me to be hooked. I ordered the 44052 kit (which i hope is correct) and started mid day today and recently finished after my wife watched the kids.
Just some notes on the parts, parts are nice quality nothing was missing. Install would have been a walk in the park except for the rear bump stop removal. That part really sucked and i've read other posters mentioning the same,,, they are right. Its not easy to get to the welds with a 4 1/4 grinder but its past me now :superhack: Think i was so pissed i didn't even install the aftermarket bump stops.
The pan hard bar bracket was a piece of cake only had to drill one hole in the stock bracket and bolt it all down. The front coils were a little tricky since you have to push down on the lower control arm pretty hard to get the new spring in there.
Finished just when the sun went down, double checked all the bolts and dropper her down for the first ride. Ride is very similar and you can now feel you are lower to the ground. Shocks seem ok too which is a plus.
So there is issues and or questions. After test driving her for a hour or so I remeasured the front and rear fender hieghts. I do not understand why but the front is 1/2 higher then the rear. Front measures 35 1/2 and the rear measures 35. Is this normal or did i do something incorrect or did i use the wrong kit?
Other issue or question is the front bump stop, wow is it close to the a arm, i so want to cut it off but not sure if these is a good idea or not.
Sorry for the crappy pic's, will get some better angles with the new 22" rims as soon as she's aligned and I make sure i figure out the height difference.
Brad
N1ck
Regina Sk
Few things, that looks awesome and low! Second, love your garage and lift!
14hemiexpress
6.4l
A lot of kits I have knowtice the fronts seem to sit high witch I personally don't like. I have never lowered a truck just cars my guess is with the weight of the engine it will settle some. Love the truck these 4th gens look good dropped, if my truck was 2wd it would already be dropped just can't bring myself to lower a 4wd. And love the garage that's what I need.
B
brad65ford
Thanks for the props guys. Looks like i'm going to have to see if the front goes down, amazing how the little things get to you. Also going to cut the front bump stop. Funny but it doesn't say this in the instructions just the rears.
B
brad65ford
well decided to cut the front bump stops off, not a fun job but its done. Now if i could figure out why the back is lower then the front i'd be good to go.
Anybody have the same kit? My front is 35 1/2" and the rear is 35" and sagging. I so want to raise the back up a cut stock coil or go lower in the front.
Hopefully someone has some advice since i'm listening.
Thanks in advanced!
14hemiexpress
6.4l
I have read a lot of mixed views on if they will settle or not. My guess it they will settle I'm not sure if they will settle a full 1/2 in or not. I would put some miles on it maybe hit some slightly tuff roads and pull it back in and measure from the hubs up and not the ground up. I would hold off on the alinment untill you can make sure your happy and not going to be swapping the spring again.
lilzilla2008
Looks good! My belltech 2/4 uses the rear bump stops you just change them out with theirs, then cut off the front bump stops and bolt new ones in, easy stuff
lilzilla2008
Mine settled down some after driving, looks better now
Btw you can send that 03/04 cobra my way! Definitely my next vehicle. Makes me miss my 02 sc281 saleen
B
brad65ford
Thanks guys, i'm not sure what to do since i agree since i doubt its going to lower 1/2 in the front especially by now with all the driving ive done. easiest would be to cut the front springs but I don't want to go any lower. Suck i'm going to have to put cut the back springs to get the height i want which is stupid since it really should be right out of the box imo. I want a little rack to her just not a backwards rack
lilzilla2008, love my 03 cobra this is my 3rd one, surprised you didn't see the 13 Shelby in the pic stripe delete so it kind of unusually to see them that way.
lilzilla2008
I noticed it I'm just partial to the new edges. Even though the newer body styles do look damn nice, still waiting to see a '15 in person though
lilzilla2008
Btw that's mine on fairly level ground, it has a slight rake to the front
B
brad65ford
Looks great!!
You have the same kit? Did you settle? what are your measurement if you don't mind?
B
brad65ford
Just took some more pic's and did some more measuring, don't think its going to settle any more then it is. Not only knowing its 1/2+ lower in the rear it just looks funny , looks lower in the rear possible could be the body lines i'm not sure. It needs to be at least another 1" in the rear to make it look balanced correctly at least that's my imo. I'm wondering if these kits are universal to all cab lengths, a standard cab should be fine with this kit but with the crew cabs would have more weight in the rear which is why I'm sagging in the rear or at least thats what I'm thinking.
Now what? Do I cut the fronts or cut the rears stock coils and re-install? If i do the rears then its pointless to have purchased the kit imo, could have saved some bucks and do what some of the other guys here have done and cut their stock coils to get the exact right height they want.
lilzilla2008
I actually have the belltech kit, I can get measurements tomorrow, where are you measuring from so I get them correctly
B
brad65ford
nice, wonder if i should have went wit them. I'm measuring direction from the floor to the height point of the inter fender. Looking forward in hearing you numbers.
lilzilla2008
Will measure tomorrow, I'll be shocked if it's the same or close to yours, front definitely looks a little lower on mine
B
brad65ford
up date with 22" SRT-10 guy metal grey wheels.
Fatboy1989
