Ram 1500 no start
Hornusmc08
Alright so I about 2 months ago, my 06 ram hemi dropped a valve seat and I had to replace the piston and reseat for the valve in the process I went a head and replaced all piston rings they are clocked correctly. I replaced all gaskets when putting everything back together has new plugs, new coils and new injectors, also has a new IATC sensor, camshaft sensor and crankshaft sensor but yet not getting a start just cranks, the timing was never messed with hell I never even pulled the alternator or ac compressor to get the heads off so obviously didn't mess with the timing, all in all it has compression it's getting spark and is getting fuel with good pressure, I checked the fuses they all check out, it start and ran before i broke the engine down and now just cranks HELPPPPP
gville35
