Ram 1500 Transmission/Transfer Case Issues
4x4ram2002
Hello
I have a 2002 Ram 1500 4x4 that I'm needing help with. Out of nowhere my truck would not pull in reverse and when I try to put the gear selector back into park a grinding noise comes from the area of my transfer case. While tinkering with it I found that when the truck is put into 4WD the truck will go into all gears and move. When the truck is in 2WD the rear drive shaft does not spin but in 4WD it does spin.
Any help with this would be greatly appreciated. This is my daily driver and I'm down and out with no transportation to work.
Thanks
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Well, technically not the right section, so it could be a very different transfer case from whats on the 95-01s. Sounds like there is an issue with with the 4wd clutch.
