ram 2009 1500 shaking
choquette
CUMmins 6.7
I changed the left wheel hub and the right ext tie rod, link kit, axle, axle seal and intermediate axle. I got itit aligned at the garage but since then when i hit 90 100km/h it starts to shake and when I turn its way worst! the stearing wheel shakes and the truck too!! what could do that? it wasnt doing that before but I changed the wheels and tires (tires are at their last summer not much rubber left ! almost like sleeks)
smoothee
St. John's, NL
How much air are you running in your tires? Too much could cause issues like your describing. Or if they're not balanced properly.
14hemiexpress
6.4l
Why did you change the wheel hub axle and the tie rod? Were you chaseing the problem of the the problem arise after you changed all those parts?
choquette
choquette
CUMmins 6.7
35psi in each tires!
I changed those parts cause they needed to be change!!
it was shaking a little bit but now its like if i was driving in a rocky road! its bouncing! when I turn it gets worst!
I read it could be an u joint on the driving shaft!!
jwheeler
Washington
If it just started after doing a bunch of work to it, make sure it is all right. Make sure everything it tight, bearing and tie rods seated properly. It you just put on a set of old tires, make sure none of them have lumps. Tires can go bad and get lumpy. Jack it up and doing the tire. Watch closely for it being out of round.
choquette
choquette
CUMmins 6.7
im gonna jack it up and see if its the tires!
peter123wallace
3.7L V6
Did you check the rear mount under the transmission? There could be a bearing somewhere as well.
Hootbro
U.S. Army Veteran
Army
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Just because the hub was new does not mean it was good. Would be double work, but you could swap the hub with the other side hub and see if it travels. I would only do this if all the other suggestions of re-checking the install does not show anything obvious.
jakeacline
Houston, TX
mine used to shake before I got my tires balanced
14hemiexpress
6.4l
If it's worse after the new parts you need to go back and reinspect the work to make sure everything is right.
