Ram 2012 tail lights
oldUncle00
Colorado
Hello I installed led taillights on my ram 2012 they come on the 2013+ models I purchased a harness specifically designed for the purpose of using those on my 2012 my friend with a 2011 got the same harness and got his new led tail lights running however mine only work when I brake and use my signals the running lights don’t work. All my fuses have been checked Here’s the harness I am using https://retroshop.us/collections/4th-gen-ram/products/13-tail-light-adapter-v2-0.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You should contact Jeremy at Retroshop. He can get you squared away.
Phillirdwn
Florida, USA
Using ram LED tail lights on my 2012 too, and they’re a bit finicky. I had success adding a small resistor to the running light circuit — seems the BCM wasn’t seeing the correct load and wasn’t sending full voltage. Cheap fix and worth trying before replacing the harness.
