Ram 2500 6.4 shutter when towing
Challenger13
Nebraska
I have a shutter when towing and slowly accelerating while turning . Anybody else having this issue ?
mtnrider
Georgia
If it's only when turning it sounds like an axle u-joint binding. Does it feel like it's in the front end? The only other thing might be the transmission but that would do it whether you are turning or not.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
I notice a bit of front end binding when I make turns. It's not very noticable. Been doing it for awhile now.
Not enough of an issue to me to take it in, but that may change as I near the end of my 5yr powertrain warranty
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
That same issue showed up on my 3500 at around 15k miles. I changed the rear end fluid and the issue all but gone now.
62Blazer
Midwest
If you have the factory limited slip rear axle it can do that. Every once in awhile I notice a small bit when empty, but more pronounced the more weight I am towing.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
I have 15,400 miles on mine and it's a recent issue. What gear oil did you use? I have the anti spin rear diff. I was planning on serving both diffs, transmission and transfer case (and drain and flush the radiator and overflow tank) at the 5yr mark so this is good timing. Thanks
SYKRAMMAN
Banned
Jersey shore
06 Mega
Mines an old girl with the 10.5 aam, but, had the same shutter when turning and towing heavy loads, switched to Redline 75w90 gl5 and it went away, had 30k on old fluid and it was still mostly clear with very little on magnets.
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
I used the OEM called for type fluid, and yes mine diff was also the anti-spin version too. I used the supertech synthetic version of fluids from walmart.
