Ram death wobble
ptuttle78
Started feeling like my right front tire is wobbly going about 65. Anyone else experience this?
1500? First check wheel balance, then start looking at suspension. This issue just recently showed up out of nowhere?
P
ptuttle78
Yes. 1500. Thought maybe it would go away with new tires and balance, but still there
H1Chester
mods? lifted? lowered?
muddy12
Indiana
I’d strongly suggest checking everything, including the alignment yourself. I had my front end checked several times by the one local shop that I trusted, and every time they told me “it’s all good, nothing out of spec”.
I ended up replacing lower ball joints, upper control arms, CV shafts, and doing the alignment myself. All of the joints were just barely within spec, but the combined slop was enough to cause problems. And, the shop had my toe set to 1/2” out!!
quietpeen
2021 TRX
Hellcat
Just to help avoid future confusion, there is no such thing as death wobble with vehicle that have independent front suspension. Death wobble only happens on solid front axles.
how old is the truck, how many miles are on it? Definitely sounds like something is warn causing excessive movement
P
ptuttle78
It feels like a death wobble. It’s a 2013 with 117,000
P
ptuttle78
Thanks. I will check into it
P
ptuttle78
Yup. Found out where all my vibration was coming from. [emoji30]
OCDTech
Louisiana
Seen this thread, and somehow on my youtube suggestions this pops up,
When i first started watching, i said, ohh ohhh ya bought a ford didn't ya? THEN I GOT TO THE 7:07 mark! (Keep watching until they show it from the outside.)
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Just throw a little grease on it. It'll be fine.
JayLeonard
6.7 L Cummins
Once the boot integrity is gone it's lights out in short order.
