ram dual exhaust
steveo2155
I love the look of rear bumper cut outs for dual exhaust on 2009 & newer half ton rams. Can you replace 2006 - 2008 ram rear bumper with the newer ones that have the cut outs? Anyone ever do this?
S
steveo2155
Anyone? This seems like a hard question to get an answer to. Ive searched the internet without much luck too...
preachp
The Con State (CT)
Hi steveo2155,
Can't answer directly but if you measure the width of the frame rails and the locations of the mounting holes from the end of the frame rails. If they are the same then you can at least mount it using the 09 brackets. If you measure the mounting points on the bumpers and they are the same then you should be able to use it with either bracket.
Good luck,
preachp
caps
Tampa
2006 Thunder Road
It requires a bit of fabrication from my understanding.
noraa73
