ram rebel wheels and blistering 5100's
Racing Woody
Dublin, OH
I have read all 368 posts in the leveling sticky thread. I have a 2015 5.7 quad cab and I am running Rebel factory wheels. I will be upgrading to the Bilstein 5100's to level. Will probably be adding a 1" spacer on rear and setting fronts at 2.8. I would like to go to a 35x12.5x17 BFG tire. 3 questions
1. What is the offset of the factory Rebel wheels? Will my set up work with out wheel spacers?
2. Has anyone used the pro comp shocks with height adjustment over the Bilsteins?
3. I will eventually be adding a 1-1.5" body lift or additional lift, looking for 4" total. I want to make sure anything I buy now, I will not need to buy again when I go higher.
This simply for looks, I drive on the high way and construction sites, no off-roading.
Thanks for the help in advance.
Woody
ram1500rsm
Trabuco Canyon, CA
Your wheels should have 18mm offset, and for what i've read in the RAM Rebel forum there is people running 315's/35's without wheels spacers, worst case you'll have to add them.
bruiserRAM
Eastern Sierra, CA
From the rebel forums:
2015/16 Rebel stock wheel and tire data
stock wheel:
size: 17" x 8"
offset: +18.05mm
bolt pattern: 5x5.5" / 5x139.7mm
weight: 29 lbs.
Fryekenn
