Ram Rebel wheels on a Laramie?
gregshin
NA
NA
I wonder if the rebel wheels will fit without any fitment issues on my 2015 laramie with factory air suspension.
BlownGP
Houston/Baton Rouge
Should, there not much bigger overall then stock and the rebel has air suspension too.
I would think right now, it would be way cheaper to go aftermarket.
6.7CumminsDrvr
The Dude abides………
Georgia
Should fit just fine, 285/70/17's on the Rebel? The stock 275/60/20's actually measure out a smidge taller overall.
xrsman
Ontario
3.0 Ecodiesel
Yes they'd fit fine..but would cost you an arm and a leg to buy!
G
gregshin
NA
NA
thanks guys i'll just lurk on the forums for a used set.
i wonder which is heavier the larmaie 20inch wheels with tires or the rebel wheels with tires?
AzRamLover
Laramie 20s ~32 lbs ea (last time I did a search - can't find a definitive one).
GY SR-As in 275/60/20 are 40 lbs per GY and TireRack
Total = ~72lbs per corner (32 + 40)
Rebel wheels ~? lbs ea (let's say they're really light; the lightest 17x9s that fit our truck aftermarket are ~24 lbs ea, assuming you don't go crazy and pay for multi-piece, forged wheels)
Toyo Open Country in 275/70/17 are 56 lbs per Toyo website
Total = ~80lbs per corner (24 + 56)
vancan
Gregshin, did you ever go ahead with replacing your Laramie wheels with Rebel wheels? I've thought I'd like to do the same. Please share a picture if you have, it'd be great to see how it turned out.
Thanks
butterscotch71
Central Ohio
2023 Limited Longhorn
I passed on brand new set of takeoffs with tires local on craigslist a couple months ago when I was looking for winter tires. Guy wanted $800 for everything. Probably should have bought them at that price.
