Ram Running board brackets
Dans Dodge
Bakersfield Ca
I have 2020 Ram Big Horn short bed with factory running boards. There are only 2 brackets holding them to the truck front and rear nothing in the middle but there is a place with the factory mounting in the middle but no bracket. So, I have tried to order the bracket which would be the same as the front and rear bracket. Went to the dealer junkyard online can't find the brackets anywhere and the dealer cannot get them. Called Dodge factory can't order then there either. I want a middle bracket because that is a long span for running boards and would stiffen up the step up. Why Dodge didn't put the middle bracket on is beyond me.
14 Lonestar
I have the OEM boards installed and have 3 brackets on mine, they are not wheel to wheel style boards.
Brian2081
Weatland Michigan
I Googled "2016 ram oem step brackets" found the nice big wide ones and the little skinny things they are using now.
lchicago
