Rambox light
56PW17
Pa
hey guys,
The other day i decided for some reason to press the yellow on/off switch in my drivers side ram box. Haven't been able to get it to turn back on since. Passenger works fine.
Wondering if i broke the switch? Anyone have any idea? I would imagine they are on the same fuse and the other side is working so i dont think its a fuse.
Does anyone know how to remove the switch? Do i need to remove the entire box?
56PW17
Pa
no one has had a similar issue?
turkeybird56
Central Texas
Sorry, cannot help, no Ram Boxes. But a thought. Check your fuse wiring diagram because U neva know. There is the possibility that one side wired to different fuse since they work independently... Of course, Murphy's Law may have struck and U broke the switch, just saying..
Maybe can U pull lens cover and see if there is power present????? Just thinking outside the box
Moparfanatic21
U.S. Marine Vet - 0321, Now a Doctor...of Vehicles
Easy way to tell is pull the switch out disconnect the connector and run a power wire to the power side of the connector. If it lights up bad switch. Or take the switch from the passenger side and move it to the driver's side.
