Rattling in front end
Cbuts05
Replaced shocks and quick struts in front ..everytime I hit a bump I hear a rattle
Any help appreciated
MTLHEMI
HEMI 5.7
Could be an end link or a control arm bushing that's loose
Sent from my SM-A500W using Tapatalk
usocazy
San Antonio, Texas
Hemi 5.7l
^^^that's my bet. That's what rattled on my front end for months before I figured it out. Inexpensive part, 20 minutes to replace.
C
Cbuts05
Shop noticed loose spindle , said I needed lower ball joint , sway bar bushings .
Took to other shop
Replaced sway bar bushings
Spindle
Left and right axle shafts
Still rattles ? Lol..hear it more at higher speeds over good bumps
MTLHEMI
HEMI 5.7
Did you change the ball joint as well ? Another option maybe is the steering linkage . Can you feel a loose in the steering at all ?
C
Cbuts05
Hey guys I apologize the late response .
Finally took it in due to rattling and was leaving for a trip .
Was told by one place
Bad spindle (wait whoever did struts didn't tighten,myfriend?)
Lower tie rod
Swaybar bushing (two rubber peices on a bar in front
Alignment
Took to another place .
They replaced spindle , left right axle shafts , sway bushings.
And sure enough, I still have a rattle ???
And driving on highway to vacation it wants to pull left a ton, I'm guessing I still need an alignment ..
But what could this rattle be !?!?!?
