RC Lift Questions
ap577
Camp Pendleton, CA
Any of you who have it install it yourself?
Any problems you run into?
Also did you have to get extended brake lines?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You looking for a body lift or what? There are a few lifted RC's here.
Oefootball_70
OLATHE
So 2wd right? Pm weedahoe. He is the only one on here that I know of that installed it himself.
ap577
ap577
Camp Pendleton, CA
Yes 2WD. I went with the rough country 3" Kit. Haven't installed it yet.
I was wondering if I'd be able to run 1.5" to 2" Coil spacer on top of the 3" Coils? Would it hit the UCA and would I have to get new shocks or the ones that came with the rough country kit suffice?
Oefootball_70
OLATHE
Yes it will hit, and put extreme wear and tear on the ball joints.
If you want to stack a spacer buy the does tech spindles and use your spacer. That will put you are 5 inches of lift and runs 2 inch block in the rear.
ap577
ap577
Camp Pendleton, CA
Damn, Ill just put on the 3"' Kit and if I want to go higher get the 3" Spindle from airbagit.
I really need to install it soon and put on my bushwacker fender flares!
KAKA
