RCSB Audio Build
Big Boi
S. Fla
When you cover the floor and walls, are you gonna lay down mlv first then the stinger deadener?
And on a side note, should I lay it down like that as well?
Etroze86
Etroze86
Grand Forks ND
stinger is already down that goes straight onto the surface you are trying to kill vibrations on and the mlv will go on top of it to act as a sound barrier for any other stray road noise.
Etroze86
Etroze86
Grand Forks ND
Stinger where you have it on the sheet metal than put some on the plastic inner door peice, hange the mlv and you can also deaden the door card.
Etroze86
Etroze86
Grand Forks ND
OK so after I finished trimming and mounting the door card everything just seems way more focused. Keep in mind I only have xovers set so no actual tune
Etroze86
Etroze86
Grand Forks ND
Had my short drive to work this morning and man it seriously cuts down on road and engine noise. I also found if I sit in the exact middle of my truck holy @%#$%$#$& mid bass is there that I have been missing with my pro audio speakers.
Etroze86
Etroze86
Grand Forks ND
Small like 14awg but mine doesn't have an internal amplifier on it so it doesn't draw much current.
Going to try and get the passanger seat back in tonight and work on gains and level adjustments but it looks like rain is coming so I'm not holding my breath.
Etroze86
Etroze86
Grand Forks ND
Oh I forgot to mention my 1200.1 will be showing up tomorrow so I might as well wait to tune so I don't have to go over it again.
BradKnob
Prairieville, LA
Yea, I hear that. Don't wanna have to go through all that twice. Just when I was getting mine dialed in, I sold my tweets and pods to ramflex. Been so busy on his stuff I hadn't touched mine. Now I'm Rollin with only 5200hz and down.
Now that I've fed the bass head inside of me, it's time to get back to the SQ drawing board.
Etroze86
Etroze86
Grand Forks ND
What are you planning for tweets?
BradKnob
Prairieville, LA
I have a set of SEAS Neos I impulse bought in DIYMA a few months back that's been laying around. He gave me his old sail panels so I'll just build a new set on axis like my last ones
Etroze86
Etroze86
Grand Forks ND
Nice tweets I'll need some pointers when I do my xbl tweets in those panels.
Big Boi
S. Fla
Same here, now get to work Brad!
BradKnob
Prairieville, LA
I'll take what I learned from the last ones and build the perect sail panel and share the knowledge!!!
But before that, there is 1 little thing I MUST finish first...
Now Let's see u do that to your balcony charonblk. Lol. Ok, not lol, I'm pretty ashamed to share that pic :(
Etroze86
Etroze86
Grand Forks ND
Hahahahaha I don't want to show you my garage right now either it is a wreck.
Big Boi
S. Fla
Wtf? I thought you released that best already?
And my ADD would not let me work in that mess. Granted I may leave a mess after I do work. But I'd HAVE to clean it before I start anything else. Hats off to you bruh!
topherztoyz
