VegasDragger45
- May 24, 2010
- 2,080
- 1,027
- 2013
- 6.7
So I decided I wanted to add a 4 channel amp. Being that I wanted both amps to match I sold my kicker sub and amp and purchased a new 10" SKAR sub. On Friday I will be ordering the SKAR LP-750.1 and SKAR LP-60.4. So since I'm adding a new amp I went ahead and ordered all new rca's from Knu as well as the negative terminal to match my positive. I will be running a 0 gauge dual amp kit from Knu when they get back in stock and doing the Big 3 at the same time. I will be using my same single 10" ported FoxBox with amp rack so i'm going to build an additional rack for under the driver side rear seat to mount the 4 channel and distro blocks then spray it with bed liner. This will also hide the wires and give me a place to drill through the cab and mount my ground to the frame.
2 channel RCA
Karma SS 2 Channel 6 Meter RCA Cable - Merchandise
4 channel RCA
Karma SS 4 Channel 6 Meter RCA Cable - Merchandise
Negative Terminal
Bassik Negative Battery Terminal - Merchandise
Top Post Adapter - Negative - Merchandise
New SUB
SKAR Audio IVX-10 V2 D2 10" IVXv2 Series Car Subwoofer
2 channel RCA
4 channel RCA
Negative Terminal
New SUB
