Re-gearing needed?
Ryanf2424
Houston
Planning on getting a 2022 Ram 1500 5.7 Hemi with a 3.21 gear ratio, will I have to/ should I have it re-geared for 35" tires? Will have a 6" lift as well.
DILLIGAF
Canadian Forces
Canada
Order it with 4.10s off the bat
Ryanf2424
Ryanf2424
Houston
Would 3.92 be sufficient enough? I'm hearing it's hell to get anything other than the three options they offer. I'm sure 3.92 would be way better than 3.21 anyway.
It's the front differential that's the hang up for going lower than 3.92. With the Gen4 body trucks, you could get lower gears for 2010 and older front difs. People would swap those into newer trucks, I think you had to use the CV shafts also. Not sure if it's possible to retrofit one into a Gen5 truck.
The first two gears of the 8HP75 are 5.0:1 and 3.20:1, that should get you moving with 35s unless you plan on towing.
Ryanf2424
Ryanf2424
Houston
Thank you guys, I appreciate it. I think I should be alright!
Ryanf2424
Ryanf2424
Houston
Just saw its not too late to switch to a 3.92.should I switch or stick to the 3.21?
REDNECK28871
Montour NY
2021 RAM 1500 CLASSIC 5.7
I have a 2021 Warlock 5.7 witth 3.21s with 35's I tow a 26 ft 7800 lb camping trailer with no problem . Wasnt sure how well it was giong to work but with the 8 speed tranny no problem at all.
Minotaur 013
Law Enforcement
Oregon
I have a 2016 Ram Minotaur running 35" tires, 3.92 gearing and 8 speed auto. This is a very good combination for performance and power. Would recommend the gear change if it's within budget.
Devin Taetsch
orange county CA
The truck I’m purchasing has 3.21’s bummer… Lol, not sure I plan to lift this one though. Probably going to be an old fart and run it on the stock 22’s.
ASPLR
Pensacola FL
HEMI 5.7
2019 Ram 1500, 5.7 HEMI, 4X4, 3.21 rear end. I'm pulling an rv at about 3500 pounds loaded. I know it's sufficient but I'm thinking of upping to 3.92. Will my rpm's decrease with a different rear end? I run the hell of rpm's when traveling. 3000 plus! Would I have to change anything up front because of 4X4? I put the truck in 4WD Auto if it's raining. Thanks for your input. I'm happy to provide more information if needed.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
Your rpm's will theoretically increase if you change to 3.92. I suspect your rpm problems are caused by your transmission shifting to lower gears to keep rpm's in the power band. So changing to a shorter rear gear could decrease your rpm's if the trans doesn't down-shift as much. Yes, you would also need to change the gearing in your front dif to match the rear. The gear ratio needs to match front to rear.
First is 4.71 and Second is 3.14
I have to wonder if that's a lack of copy-n-paste as those are the gear ratios for the 8HP70. The 8HP75 has a wider gear ratio spread from 1st through 8th, the 4.71 first wouldn't contribute to that.
WY-Dave
Air Force
Cheyenne, WY
6.7 CTD
I used this calc when I was in the Jeep world. You put in new size, old size and it will give you the the current "effective" end ratio (gears + tire size). Then in the New Ratio it gives you what gears that you would need to keep the same performance of old tires.
This one gives you what the engine rpm at an entered speed. Do one with stock, then with new setup and compare. IF you can figure out what the top gear ratio (od) is then change the Transmission ratio to that. Or just leave at 1:1 and see the gear differences.
Markmitchell71
