Readylift and shocks
Samb992
Dallas
So I just installed my 4 inch readylift sst kit and 5100 bilstein shocks all the way around my truck in the front still doesn't sit level I was wondering if anybody has adjusted the front shock up to another slot other then the stock setting while having this lift truck rides amazing no problems but I want it to sit level is all if anyone has done this let me know if you have an if you had any problems doing it
Sent from my SM-N975U using Tapatalk
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
That’s the point of 5100s: to LEVEL the truck by using the 5 grooves as your need fits. Looks like it’s gotta come apart again to get it “leveled”.
S
Samb992
Dallas
Alright yeah people kept telling me to leave them at the stock setting while running the 4inch readylift because of the angles
rwhjr
maryland
If the lift kit he’s running didn’t come with front knuckles etc to correct for a higher lift (isn’t ready lift one of the lifts without knuckles?).......
Then he might be begging for trouble. If you’re lift currently features 4” of lift provided by spacers and you’re on the factory knuckles then I’d advise against the above poster and leave the front struts at stock height.
But if it’s a true 4” lift with diff drop brackets/knuckles you’ll be okay going higher than stock height with the struts.
S
Samb992
Dallas
It is the sst kit it came with spacer overload spacer and the upper control arms
rwhjr
maryland
To me it doesn’t seem wise going even higher on stock knuckles and without a diff drop etc.
But maybe someone here’s got more info with this specific kit.
S
Samb992
Dallas
Okay yeah I was thinking about that i just put it on so if i can't i will just go woth the bds kit in a couple months
KiltedCelt01
PA
You can’t raise the front any higher than how it is now with the SST kit on or it will throw off the geometry in the front end. Stock height struts in the front only. If you installed Bilstein’s, they need to be set at zero. I have this same kit in mine.
DILLIGAF
Canadian Forces
Canada
A proper lift comes with knuckles.
