Looking at the picture and seeing no oil on the flange, they likely drained the oil and failed to add new oil.Hello all. My vehicle is a 2016 Ram 1500, 5.7, crew cab, big horn. currently around 54,000 miles.
So yesterday I went to the local oil change place to get my oil/filter changed. they suggested change the front & rear differential fluids be changed as well. I said ok.
the receipt says they put in 75w90 x 2.4 pts in the front & 75w140 x 4.6 pts in the rear.
Mileage in was 54103.
I drove home, maybe about 2 miles away. took side roads. did not go over 50mph. No issues.
today i got on the expressway and i smell a burning oil smell and the truck is kind of "holding back" when i let off the gas pedal. the same feeling you would get if you were to put you car from "drive" then shift into "2" or "L". that sensation. I got off the nearest exit and now im on the service rd heading towards a red traffic lite and i hear a snap/bang sound. then a dragging sound. i feel no forward power when i press the gas and now the engine is sounding very weird. as if it were getting flooded from too much gas or something. I stop at the red light. now the smell is very bad and the engine seems to be stalling. i put it in park and shut off the truck. i get out and the truck starts rolling backwards because i am on a slight incline. i hop back in and press the brake and emergency brake. i get out and look underneath and find the rear driveshaft snapped and hanging on the street. see the attached pics. the mileage now is 54112. Ive driven 9 miles.
how can it be that a driveshaft snaps like that? any thoughts? looks like a clean snap.
Yeah, I've seen diffs seize up from no lubrication, but I've never seen a catastrophic failure like that. I'm suspicious, too, there's something in the diff that shouldn't be there.It’s a long shot but it’s possible the grease changer left a socket or extension laying in there . Make sure it’s documented with photos as it is disassembled. Let us know the outcome please, thanks .
I bought a mustang not long ago that I’m rebuilding. When I pulled the engine and transmission, I tried to push it out of my garage but the rear end was locked up. I took the rear WBS out and took it to have it rebuilt. The shop called and said it had to have been empty for a while and everything was destroyed. LSD clutches were basically melted, and this is what’s left of the bearing cage that was on the pinion. I had to buy an entire new rear end because this one was all gouged out and beat up inside.Of all the bearings in the rear differential, the pinion is the one that spins WAY faster compared to the axles. It will build up more heat. At about 1500 rpm the pinion would be spinning, about 1850 rpm (rough numbers -- will vary depending on gear ratio). The outer axles would be roatating at about 630 rpm (depending on wheel diameter). 630 rpm is like nothing in the world of bearings. The actual bearing rollers themselves rotate much slower than the axle shaft ...and the wheel bearing race can usually retain a spoonful of lube. Unloaded in cool temps, outer bearings are at less risk.
The pinion though will build up much heat, and soon seize. Yeah, it got so hot it melted the bearing and probably snapped off at the hot and weakest point. I bet the whole gearset and their bearings are quite a sight! Give us a complete autopsy when they take apart.
Course it's also possible there is enough lube in there and the pinion bearing cage failed (which they can and do), and took out the pinon. I've seen that happen.
