dale.
I installed a rear view cam today I did see picture but it wasn't good because the reverse lights stayed on in park lmao. That was when I splice into the reverse light since then no picture. I have a Pioneer 4600BT and I am using the axxess xsvi-6522-nav harness kit. Hooked everything up like it should for the radio/harness. Now in the picture should that red wire with the video cable connect to the pig tail and at the radio end red wire hook up to the reverse signal wire which is currently connected to the box in the xsvi harness.
