Rear dome light replacement bulbs??
mjscharlotte
Charlotte, North Carolina
5.7 Hemi V8
Hey guys,
I am in the process of switching my factory interior LED bulbs to aftermarket ones. I got the front map lights done and thought I was getting ready to do the rear dome light. Apparently, there are 2 different bulbs for it. I ordered these from Amazon but when I removed the light there’s no where for these to go - it’s just a small LED panel. Do I need to get another LED panel like Boostedram did and install that way or is there another way of doing
Alla Lighting CANBUS 211-2 578 LED Bulbs Super Bright 41mm 42mm Festoon 3030 SMD 212-2 569 6413 LED Lights Bulb for Interior Map, Dome, Trunk, Step Courtesy, License Plate Lights, 6000K Xenon White https://www.amazon.com/dp/B014P0HTKE/ref=cm_sw_r_cp_api_fabc_N8tVFb6HM791B
ricky_bobby
Wake County, NC
6.7L Cummins
I had the same thing - the factory dome with rear LED - once I replaced the map bulbs in the front, I thought 'hmmm' -
What I did was buy the 'normal' halogen rear dome panel (I forget the part number but its probably the same one for a Tradesman), which just has a regular festoon bulb, and then I replaced with a white LED festoon panel replacement - the housing is 'cleaner' looking on the LED version from the factory, but I didn't want to mess with buying panels, gluing them down and soldering wiring in etc -
Reticle918
