Rear end compatibility
Max1329
5.7 Magnum hemi
does anyone know if a 4th gen ram 2500 could go on my 05 1500
HemiLonestar
Navy Badge Coast Guard
MD
1. No, different platform and on top of that 2500's went to coils for 2014
2. Why?
Max1329
Max1329
5.7 Magnum hemi
Your right I forgot about coils. And I have an open dif and can’t stand it anymore so I fogured with a 1/2 ton rear end I’ll have posy and never have to worry about anything
2. Why?
HemiLonestar
MD
You originally said 2500, based on that statement I assume you originally meant 1500?
Max1329
Max1329
5.7 Magnum hemi
Nope I meant 2500 I have a buddy with a 4th gen 1500 who swapped to 2500 and is very happy with it
HemiLonestar
MD
Ok, then why did you say this:
Either way, as I see it you have two options here. Get a good aftermarket LSD for your 9.25 or switch to an SRT D60. Pros and cons of both:
9.25
Pros - doesn't require any adaptation, gear sets available through 4.56 and options for LSD install
Cons - expense of install of gear set (if wanted) and/or LSD on top of purchase price
For what it's worth, my '74 Monaco had a 9.25 rear behind a 440, it's a stout enough piece in the trucks just the factory LSD would grenade and destroy it; you were saved from that carnage with an open rear lol
SRT D60
Pros - 9.75" ring gear, it's quite strong (stood up to the torque of Viper engine manual trans launches) plus the axle comes with a stout factory LSD (if it hasn't been abused too much), almost a factory bolt in
Cons - not quite a complete factory bolt in, requires a custom driveshaft to mate with RFE, only available with 4.10 in RC (factory lowered) or 4.56 in QC (factory normal height)
Max1329
Max1329
5.7 Magnum hemi
9.25
SRT D60
So I shouldn’t even try junkyard shopping? I was thinking about just picking up a complete assembly and having it rebuilt
Max1329
Max1329
5.7 Magnum hemi
9.25
SRT D60
Would lockers be the way to go then?
HemiLonestar
MD
You can do that, but look at the cost of buying the diff and the parts/labor for rebuild and compare it to just having a DTT or similar installed in your existing diff.
I wouldn't do a locker on something that sees consistent street duty.
Max1329
Max1329
5.7 Magnum hemi
Good point any brand preference of a ddt?
HemiLonestar
MD
DTT = Detroit Truetrac
Comes down to preference vs cost. Do some searching on the forum and some online shopping.
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
I second the truetrac. helical "LSD" are great for on road performance. Plus doesn't need additive in the gear oil, minimal maintenance since there's no clutch pack. I put one in my GM 12 bolt when I built my chevelle and now have on in my 73 D100 8 3/4 rear end.
Max1329
Max1329
5.7 Magnum hemi
Alright great looks like that’s my plan thanks alot
