Rear end grind
Runner06
Stuart Florida
6.7 cummins
i have 2018 3500 4x4 when in 2 wheel drive and i start to accelerate from stopped it feels like the gears are not meshing or does it have clutches limited slip rear end
Generally it is more noticeable when slight turn or full turn?
RamCares
n/a
n/a
Hi @Runner06,
We're sorry to hear that you have these concerns with your 2018 Ram. Have you made your Ram dealer aware of this concern? Please send our team a private message if you are in need of additional assistance while at the dealer.
Darlene
Ram Social Care Specialist
R
Runner06
Stuart Florida
6.7 cummins
No I have not, I was curious if anyone else was experiencing this issue.
I will check in with them.
Thanks
RamCares
n/a
n/a
Understandable, @Runner06. Let us know if you would like support from us.
Darlene
BrewCrew
Lake Arrowhead
HEMI 5.7L
I had a similar issue. It turned out the dealership forgot to add the LSD additive when they changed my differential oil.
Fuel35 67
Hanford
Why does that bad copy of the Detroit True Trac need an additive? The answer is they don’t. Only the clutch style sure grips require it.
