Rear end squeak
usmc1217
Fremont, CA
Hey all
I have a ‘21 ram 1500 limited with about 58k miles
I noticed a distinct squeak (like metal and rubber rubbing against each other)
About 3 days ago and it has progressively been getting worse.
It first started when vehicle was moving 25-30mph but would stop around 65mph+
Now it’s to the point where it’s constant from 1-60 mph.
So far I’ve removed the rear tires and checked the brakes. Everything looks intact, nothing stuck between the aluminum shield or no loose or missing caliper parts/clips
I sprayed all the bushings I could find with lube and still persists.
Tried driving with the tailgate down and noise is still there.
Tried manipulating just about every moveable part while under the vehicle and couldn’t replicate the noise.
I’m at a loss…
Early on when I first got the truck, I had similar issues which turned out to be tie rod ends and dealer replaced them.
Douma
Carlisle, ON.
Rear diff fluid perhaps? I had to bring mine in at 15k. Mine was more of a rubbing/humming at slow speed turning. They suspect the friction modifier in the diff fluid was either missed or not enough from the factory. Inspected the clutches in the LSD, fluid swap, and its been quiet and smooth since.
mstevens
Fort Worth TX
Hey all
I’m at a loss…
usmc1217, did you ever figure this out? I have a 2022 1500 classic and this sounds awfully similar to what i have had going on for a bit now. Except mine is front passenger side. Less than 40k miles. With how notorious rams are for ball joints, I assumed it was that. Mine was a little loose, but nothing crazy. I replaced the control arm anyway. it was silent for all of one day, but now we are back. Started slow, but has gotten worse by the week. I can get the distinctive squeak rocking the truck side to side, driving straight at any speed, and when making left turns. it does NOT squeak when making a right turn.
