Rear pwindow won't go up
will530
Nor Cal
Rear window won't go up
I have a 2011 sport crew cab. The passenger side rear window won't go back up. Would not go up or down at the master control switch. I opened the door and it only rolled down with the switch at that door. Now won't go up.... Anyone had this problem before? The other windows, when all the way up, I pressed the switch up and you hear a small clicking sound, the one that doesn't work will make no sound when I held the button up.
Dodgetk81
I know on some older Rams, the wiring in the door hinge area breaks over time from use. Never heard of it on a 4th gen yet, but your Simpsons sound like that us your issue
W
will530
Nor Cal
Thanks, I opened the panel and pushed my wire's in tight to connections at the switch, it started working again. We'll see if this is the problem.
gofishn
Iowa
hemi 5.7L, 345 cu in
Wiring cracking, between the cab and door, is a known issue.
Angles are too sharp and not enough play.
Had to have mine fixed too
