rear rotors, some things i learned
bigtigga84
dela....where?
didn't know that the parking break is a shoe set up, so the rotor is a rotor/drum.
turning the rear axle is a ***** without the wheels on, helps to take both calipers off and use something(i used the hammer i was tapping the rotor off with) to turn them.
the **** that is suppose to stop the pads from squeaking is sticky ****, but it stopped mine from squeaking.
wasn't that bad at all, i have done a lot harder stuff. best of all my ass isn't hoppin around when i hit the brakes any more.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
Glad you got it sorted. Those shoes cost twice as much as a set of rear pads, the spring hardware kit is what failed on mine at around the 200 K Kilometer mark.
quietpeen
2021 TRX
Hellcat
did your rotors come off easily? On my 05 the rear and the front rotors were a ***** to get off.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Tyler told ya last night good job but give it another that'a boy on here lol.
bigtigga84
bigtigga84
dela....where?
Wasn't real hard to get em off. Definitely didn't just pop off, but a persuading device helps lol. The fronts popped right off when I had to have them turned last year.
Thane's for answering my post blond moment question ken lol. Something I should have added to the first post, but this would be one instance were setting the parking breaks would be a bad idea lol. I did and then went...... wait a minute......... D'OH!
NJDodger
Armpit, NJ
I know when I did mine I was surprised to find the rear caliper slide pins were more gunked up than the fronts. They needed a good brush up and lots of grease. On all my other vehicles the fronts were worse from the extra heat.
nussdawg395
PA
5.9 Magnum
Good info man! Thanks for sharing!
bigtigga84
bigtigga84
dela....where?
No prob, it's little stuff like this that might really help someone else.
LB3711
Trumbull, CT
3.6L V6
i hate rear rotor/drum combo. I had a ton of issues with a jeep grand cherokee brakes.
