cneagle87
2011 Ram 1500 4x4. Hope I'm posting in correct place. I bought this truck in Jan and notice there is a good amount of roll and sway with it and almost jumpy when going over rough spots on my road and lower speeds. I have just put bilsteen 5100's on the rear and will be replacing the fronts too shortly. I have been researching rear sway bars and the Hellwig is on the todo list. But I looked at mine and noticed that the rear sway bar is not sitting level. It is angled upward. Will this have negative riding affects?
I am not sure if my truck has the factory 2 inch lift that I have read about. It is sitting on 35 Nitto Terra Grapplers and the top of fender sits 8 inches above the top of the tires. Do I need to get longer rear sway bar links to level out the sway bar? I will post pics of the sway bar and of the truck. Thank you all for all input.
It also already has the 5100's on the front and the driver side is on the highest setting and have noticed the passenger side is on the next to highest setting. Not sure why that is. But do I need longer front sway bar links with the 5100's on the highest setting?
