Rear Sway Bar
SteveCornell
I need a complete rear sway bar for my 4th gen Classic 2021 RCSB 2WD
I'm installing the MaxTrax 2\4 lowering kit, my truck did not come with a rear sway bar so what would you recommend?
S
SteveCornell
I just realized my lowering kit came with new sway bar links (DUH!!!) look like the only thing I'll need are a few bolts and nuts..... Thanks!
S
SteveCornell
If you scrounge up the rear swaybar off a 2500 Ram,it's beefier then the Hellwig bar is. You should be able to find a used one at a wrecker,and get the brackets and bolts with it,for less then what the Hellwig will cost you.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Wild One is correct, however if you can't find one off a 2500, I would recommend the roadmaster. It's an improvement over the hellwig
natehate
ontario
i'm looking into this right now using car-part.com to find one near me
my question is which one?
front, 4x2
front, 4x4, CNG
front, 4x4, diesel (6.7L)
front, 4x4, gasoline, disconnecting (electric)
front, 4x4, gasoline, w/o disconnecting
rear, 4x2, air spring
rear, 4x2, coil spring
rear, 4x4, CNG
rear, 4x4, diesel (6.7L)
rear, 4x4, gasoline, opt SD1 (articulink suspension, Power Wagon)
rear, 4x4, gasoline, w/o opt SD1
my trucks a 2021 1500 classic shortbox reg cab
edit, i figured it out by clicking on a few options
natehate
ontario
does anyone have part numbers for bushings, brackets and bolts for the 2500 rear sway bar?
MCMLXIX
Las Vegas
5.7 HEMI R/T
I asked Benny from ALLMOPARPARTS and this is what he came up with … I haven't gone any further than asking for P/Ns ….
Using this VIN to filter parts here is what I come up with
https://parts.allmoparparts.com/oem-parts/mopar-rear-suspension-stabilizer-bar-68139811aa
https://parts.allmoparparts.com/oem-parts/mopar-stabilizer-bar-bushing-retainer-52090271ab
https://parts.allmoparparts.com/oem-parts/mopar-stabilizer-bar-bushing-68160338aa
This truck has sales code SDB heavy duty suspension but not air leveling.
Bigskyroadglide
Moderator
You can get everything here except the metal swaybar busing brackets and bolts for about the same cost as the swaybar
Steve58
