Rebel wheels...question/help
amm24dmb
MA
I’m picking up a 2020 Big Horn on Tuesday. It has the 20 inch chrome wheels. I’m going to swap them out for some 275/70/18 Toyo AT3’s and then I’m going to buy some 2019 Ram Rebel Rims - 18 inch. Will they fit fine on my vehicle? I’m not super educated on bolt patterns and all that. Just wanna swap the 20’s setup for the new 18’s setup. Thanks for any advice!
As for your current swap size comparison:
The 2020 Rebel rims will fit your truck as the all use the same bolt pattern, and your not up sizing the tire much so there shouldn't be clearance issues but the speedo will be off. T
The factory Rebel tires are 275/65/18 Those would be almost a match size wise to your current wheels, not enough to make a difference on the speedometer/odometer.
A
amm24dmb
MA
thanks so much! I don’t know much about bolt patterns so I wasn’t sure about that part. I knew the new rim/tire combo would be fine, but knowing my luck I’d buy them and the pattern would be wrong! Thanks!
A
amm24dmb
MA
Oh and it’s a 2019 Rebel. Still fine?
All the 6 lug Gen5 rims should swap between each other. Apparently I can't read correctly right now, the Gen5 Rebels use a 275/70/18 tire, the 275/65/18 is the standard tire size. D'oh!
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
If your Big Horn is a 5th gen they will fit fine. If it's a 1500 classic Big Horn (4th gen) they will not fit. As long as your Big Horn has six lugs they'll work for you.
A
amm24dmb
MA
Thanks!
cdub5
