Rebuild Recommendations
DeepDive
DeepDive
DFW Texas
I’m also thinking about swapping out the transmission for an 8 speed. Are there businesses out there that do refurbished or should I bit the bullet and go to dodge?
Man you gotta learn to give more info,are you now referring to a 8 speed transmission,or are you still referring to the engine.
If transmission you can pick up fairly low milege used truck 8 speeds pretty well anywhere. A new one is gonna rock your boat,and i wouldn't do a factory reman 8 speed,as Dodge farms them out to the cheapest rebuilder who bids on the contract.
DeepDive
DeepDive
DFW Texas
I am talking about an 8 speed transmission.
Don't be scared to pass out more info,instead of assuming we'll know. You haven't even told us if its a 2X4 or 4X4,don't be shy dude,the more info you provide the better the answers will be
Pick up a low milege used 8 speed,they aren't hard to find.
If your truck is a 4X4 you'll need the 8 speed from a 4X4 as the 2 wheel drives use a differant tailshaft and output shaft,and the transmission has to be completely disassembled to change them,same goes if your trucks 2 wheel drive get the 8 speed from a 2 wheel drive truck
