Last I knew, AlfaOBD can’t do a new rf hub and fobs (unless it’s push button start). It’d be worth a try for someone that already has the software, but I’d hate to recommend someone buy it for that reason and it not work.I believe that the 2016s you'll have to buy the remote start kit (comes with new rf hub, antenna, hood latch and key fobs) should run about $250 then have the dealer add the sales code. @Jimmy07, I don't recall if alphaobd can activate remote start or something with the rf hub, on 2013-16 truck's.
2018 2500 6.4L Tradesman
If you don’t like the range of the flash logic (or any kit that uses the factory fob), don’t get the factory remote start. The range is exactly the same, since they use the same fob transmitter. I have both installed simultaneously. Good thing about the flashlogic is, you can add the drone mobile add on so you can remote start from anywhere with your phone.FWIW, pretty sure the dealer had a 3rd party install the flash logic remote start. I absolutely hate it. The range is like 25-30 feet, maybe 50 feet. Not nearly far enough to cool the truck down in summer.
Spend the extra, do the work, and get the oem kit. I'll be doing that in the future.
The antenna is necessary just to receive the signal from the fob, not make the range of the fob farther. I can assure you the range is the same between the two. I’d just hate for you to spend all that money on a new kit that’ll disappoint you with the same results. I would use the kit you have now and add this drone mobile to it- https://www.ebay.com/i/162788296878...MI3MPCh4Lx5AIVjcDACh1LVQrhEAUYASABEgITZfD_BwEThe factory kit should have an antenna and a new fob (at least it does if you do the keyless n go). The one on my JGC had a particularly long range.
I think I paid $72 for this year and can remote start with my phone from anywhere that the phone and truck have cellular signal.
