Remote Starter
BCVT1972
Southern Vermont
2024 Tradesman Crew Cab
V8
I'm having a factory remote starter installed.
Will the Ram phone App then allow me to start with cell phone?
Currently there is only Unlock, Lock & Horn on the App.
Dean2
Near Edmonton
If they install it right, yes it should. Why would you not ask them that question BEFORE spending big bucks doing this. If they can't answer that question, I would not be using them for the install.
B
BCVT1972
Southern Vermont
V8
Short staffed Monday due to holiday.
I'm fine with the key fob start button. Not a huge deal if the app doesn't allow it.
1stindoor
NC
'23 2500 MegaCab
I thought the app only allowed it if you had uconnect. Might have to revisit my settings.
mikeru
Super Moderator
Moderator Supporting Member
Eastern WA
2020 Limited
Hemi 5.7L non-Etorque
The app is nice for starting your truck when out of range of the fob. Otherwise I find it pretty useless.
Dean2
Near Edmonton
You do need Uconnect. I don't have it either, I very rarely use remote start, let alone use it where the FOB range would be an issue. I do not believe in letting vehicles run. I start it, put it in gear and drive GENTLY away while it is warming up. They heat up WAY faster and so does the Trans, diffs etc, when moving.
1stindoor
NC
'23 2500 MegaCab
Thanks. I just revisited my App (hadn't used it since I bought the truck in Sep). No "Remote Start" listed. I use the key fob all the time to start it, but usually doesn't run for more than a minute before I'm in it and moving.
geneseedennis
