Removing Pine Sap from Paint
RickOnt
Ontario , Canada
Hi Guys
At my camp we have some huge White and Red Pines, Beautiful trees but in the spring and summer they drop some sap and create a sticky mess.
How can you remove these spots?
I have used hand sanitizer works great on the glass but not sure about the paint.
Thanks
Rick
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
try an isopropyl alcohol, or a bug/tar remover. Those are good for sap.
PoMansRam
East Aurora NY
I use WD40 or mineral spirits and a clean rag. It will clean it right off.
Pull Ya
Cedar Creek, Tx
Here are a few of the products that are recommended at a professional detailer site "autopia"
https://autopia-carcare.ecomm-search.com/search
Enter "sap removal" in the search box
Additionally people recommend alcohol, clay bar, WD-40 and the hand sanitizer you have used. My only problem with a couple of these is the scratches they might leave on the surface. I would always use a microfiber towel to "rub" anything on the surface, and make sure it isn't completely dry. Usually a clay bar doesn't leave scratches if you use enough clay lube. Others may have additional suggestions.
Jay
Rowdy Ram
va
I use purell hand sanitizer it works great.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
All the above are good . I have the same issue with my trees in Maine and found Alcohol worked the best on dried on pitch ! Then a wash and wax
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Have this issue in our area with Pine tree's and other rude tree's. Been using the Turtle Wax-bug and tar remover for years. It works.
