replace 6.4l with 5.7l
natejr55
new york
6.4l
I have a 2014 ram 2500 with 6.4l hemi in it that has blown, there are none available anywhere, so i was hoping someone could tell me if a 5.7l hemi can be installed instead?
audiophile
5.7L
I sure it could. You would need the harness and module/pcm for it. The block is essentially the same. I believe mounts would be all rhe same.
White six four
Wisconsin
Have you checked car-part.com? Otherwise I've seen posted on here that companies have 6.4 crate motors too.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
ramffml
ramforum
There is also these crate engines direct from mopar, same price as above but brand new:
