Replace engine block heater
raff18
Sudbury canada
2019c
has anyone ever replaced the stock engine heater?
Mine took a **** and is not heating the engine anymore.
Looks like it’s just a 13mm and it pops out with no loss of coolant.
1985 W350
I've seen several problems here --- largely related to the fact these things get corroded, then start pulling more amps which more often than not heats up the undersized wiring many of the manufacturers use --- Ford just did a recall.
1985 W350
Undersized wiring that gets over-amp'd.................
joshhhh
