Replacement shocks for Stock height
HemiMax05
Pearland, Tx
2011 Dodge ram
I am due on replacing the shocks on my 11 Ram since there shot. I been looking to see what brands are recommended by fellow ram owners. My truck is stock height 2wd on 24"s, I've been looking at these new shocks that belltech offers for stock height trucks, has any one used these. Part# 9637.
On my past rides I haven't had good luck with the monroes, i here a lot of bilstein shocks.
What would you recommend
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
How about OEM ones? I used the BT shocks with my 2/4 drop on the front, and had issues...so put stocks back on, rode better.
arod412
Philadelphia
You can always get bilstein adjustable ones..and just leave them as is, and don't adjust the c clip on them. You will get a nice stiffer ride with them too.
Just an idea. When people get bilstein, first though is either in a lift application, or a leveling situation...but you can leave them factory settings too...which is nice.
**Truck name: Rampage**
bcbouy
pitt meadows/100 mile house
2021 power wagon
hemi
if you want a good ride with stock height,take a look at kyb monomax.i had them on my f150.pro comps were also ok,and priced really well.
BlownGP
Houston/Baton Rouge
Just went through this. The bilstein adjustable won't work on the front of a 2wd according to bilstein.
I'm problay going to go with the bilstein non- adjustable
but arent those Belltechs for lowered trucks?
http://www.amazon.com/Belltech-9637-Street-Performance-Absorber/dp/B00NBV4T34
arod412
Philadelphia
^^ that's actually a pretty good deal there for belltechs shocks. I wonder how they ride?
JasonK94Z
Anderson, SC
Bilstein 4600 shocks. I will never buy another brand of shock again.
Front: Part Number: 24-187480
Rear: Part Number: 24-187510
Graygoose
Oklahoma
Convert, for now.
small
I had to take mine off, at home sitting ion a box if someone needs a set :)
gofishn
Iowa
hemi 5.7L, 345 cu in
Buddy put Bilstein 4600 series on his truck adn he postively loves them.
Really a nice ride.
HemiMax05
HemiMax05
Pearland, Tx
2011 Dodge ram
Amazon.com: Belltech 9637 Street Performance Shock Absorber Set: Automotive
The belltech shocks 9637 according to there site are for stock height vehicles, but I wonder if they would have the same issue as they do with the drop ones fitting in front.
How was the fitment, ride quality? If you don't mind me asking how come you took them off?
BlownGP
Houston/Baton Rouge
Really a nice ride.
I will still probably go with the 4600s. I know Bilsteins make some good stuff.
Those belltechs are a good price though.
My truck seems to be making knocking noises when I hit bumps. Sounds like its coming from the shocks. Plus the trucks shimmys a little bit, might have something to do with my 22s but I think it's the shocks.
HemiMax05
HemiMax05
Pearland, Tx
2011 Dodge ram
How interesting my truck does the same thing and shakes bad once I'm over 70+mph it does it with my 20s and 24s. it seems to shake more now since my front shocks are shot and alignment is off. I wonder if bad shocks would cause these trucks to shake since there more sensible because of the spring design.
BlownGP
Houston/Baton Rouge
The shake is probably the tires need to be balanced. These trucks are picky about that.
My noise sounds like a thud, almost like the shock is bottoming out.
