Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I baked them apart on Friday night and started Saturday morning. I was done putting the projectors in at about 2, but I had to wait until dark so I could make sure my cut offs were straight before coming back to the house and hitting them with 2-part epoxy. After an hour of dry time on the epoxy, I tighten the nut on the back of the projectors and sealed them back up that night. I had everything installed and running before lunch on sunday.
I guess if I would have had a garage or a place to adjust my cut offs then I would haven been done by Saturday night.
I am starting the install now. I have the housings in the oven right now. Hopefully this part goes smoothly, I constantly check them to make sure they are not melting.
2x 5.7L & 6.2L
I've.............never melted a set of lights.
Hundreds, dare I say even a thousand have been through my oven. The key is obviously temp and time. I've read some people say 350 degrees.........what? you cooking a chicken too?
250 degrees. Hell, I left a light in the oven once for about.....30-40 minutes once (forgot to set my timer.....derr) - came out fine.
Tip - I use a silicone mat. That on a cookie sheet has served me very well over the years, in fact.......I'm using the same exact cookie sheet and silicone mat that I started with. It has one blemish on it......those pesky 2013's have some weird glue in them......some spooged out.......and its a ***** to remove!
Glad to hear your retro has started, keep us updated. The only part I hated was removing the glue from the housing after I got the clear cover off. PITA!
That glue is a PITA for sure. I've noticed that if I heat up the housing and then let it cool for a couple of minutes, the glue becomes hard enough and pliable enough to pull it out in big strips. It's just time consuming. I have about 3/4 of the glue out of the first housing.
