Retrofitting Projectors into Stock 04 Housings
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Set the oven to 225 to 235 degrees no more. Stick the housings in it for no less than 10-15 minutes. The pry them apart. There are a dozen youtube videos on this subject. You may have to reheat the housing a couple times though if you are not fast enough. When resealing them get this: OCI Butyl Rubber Glue - Accessories from The Retrofit Source Inc
It will do a much better job of resealing the headlight than anything else. Also get a complete retrofit kit from Jeremy at retroshop. You will not regret it and you will be better off in the long run. Get a shroud it wil hide the internals of the projector and just look cleaner. Again ask Jeremy what he recommends on the shroud.
Stangshcky12
Oshkosh, WI
5.9 Cummins
JJ has a right up on here with a time and temperature to heat them
Worked for me three or four times now without problems/melting
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
all sorts of fun!
I've never had to grind down that spot on the 02-05s though.........must be lucky. :D
Hit me up in email if you have any questions on the parts guys! [email protected]
THX!
Fatboy1989
