Apiazza
- Joined
- Aug 12, 2016
- Posts
- 80
- Reaction score
- 36
- Location
- Westminster, MD
- Ram Year
- 2019
- Engine
- Hemi 5.7
A month or so a go I noticed the sound of something rolling around under my truck. It was pretty obvious that on braking it rolled forward, on acceleration it went back. Always on drivers side. I got under the truck to try and source the issue, initially thinking it was a rock in the frame. After some digging around I believe I actually found it inside the body under the doors. 1 in a billion chance of kicking a rock into the tiny holes on the inner side of body. I would have much rather won the lottery...
Anyone have some recommendation for getting it out? I could probably use a borescope isolate it's location, but don't know how I would be able to get it out after I found it. I've considered pushing it all the way to the front or back and then using a bit of expanding foam to try and seal it in place. My only concern going that route is water drainage out of the panel. I don't want to trap moisture and create a rust issue. Thoughts?
