- Joined
- Mar 14, 2015
- Posts
- 1,446
- Reaction score
- 519
- Location
- NL, Canada
- Ram Year
- 2019
- Engine
- 5.7 Hemi
I thought, "what" we're past April 1st
Stop/start systems just seem unsafe to me.
Why do you think they're unsafe? Not trying to argue, just curious.
As a former tanker, I can confirm it takes about 15 gal. And I believe the total amout of fuel was 502.4 gal... With 2 gas tanksHey, on a side note, totally random, I remember seeing somewhere an Abrams tank needs around 10 gallon of fuel just to start its turbine engine! Imagine giving that f*cker start/ stop technology!! Hahaha holy crap, you'd run out of fuel on the battlefield. Now, that's "unsafe."
As a former tanker, I can confirm it takes about 15 gal. And I believe the total amout of fuel was 502.4 gal... With 2 gas tanks(technically 3 but I don't feel like explaining)
Now try and guess how many wheels they have.
IMO
Pretty much exactly what zflat was talking about, a delay in power. For example, say you are sitting at a stop, and you happen to see an out-of-control car coming at you. You hit the gas to get out of their way and your vehicle does nothing for a second or so. That delay in power could be what gets you injured or killed.
So when i start my truck it goes straight to 1 in the rpms. After awhile it drops when im not driving but not to 0 only halfway.even when i drive and i stop at red light, it doesnt go to 0.only half way. Is this a reason for concern or is it normal?its a 2015.also still cant get over how bad my mpgs are, if that's normal, then ill just accept it and move on.
You need to check your turn signal fluid, low turn signal fluid is usually the cause of this...
If that doesn't fix the issue, replace your muffler bearings that will do it for sure.
