Running Board mounting bolts don't line up
DS0292
Haskell, OK
5.7L Hemi VVT
I'm trying to mount running boards on my 2019 Ram 1500 Rebel Crew Cab. I've ordered two sets that were supposed to fit my truck and neither did. On the running boards I ordered, the middle bracket is centered between the front and rear brackets. On my truck, the mounting bolts for the center mount are about 2 inches off center, so neither set worked. Is it possible for me to remove those mounting bolts and remount them at center, or does anyone know where I can find running boards that are truly made to fit my truck?
Units
Ms
2023 Bighorn
6.7l Cummins
Just want to ask the obvious question first, did you read the instructions?
The nerf bar brackets for my 2500 were offset differently and had to be put on a specific way and if not then nothing would line up.
D
DS0292
Haskell, OK
5.7L Hemi VVT
Yes, I did. Besides, the brackets on the boards are centered and the mounting bolts are not, so . . .
gwilburn
2024 1500 Limited Crew
Hemi 5.7 eTorque
Are these Ram or Mopar running boards? When I looked at my 2024 (boards ordered), I don't see any way of moving the bolts. However, a lot of the aftermarket boards were designed so the brackets actually move on the board.
D
DS0292
Haskell, OK
5.7L Hemi VVT
No, they're not Ram or Mopar. I don't see any way of moving the bolts either. I haven't been able to find any aftermarkets that are designed to move the brackets.
Jerrybob
WA
Good question....my aftermarket boards fit perfectly on my 5th generation Ram 1500.
YITAMOTOR
US
Hemi 6.1
I recently purchased running boards from YITAMOTOR this year and had a positive experience. The installation process was remarkably straightforward. After laying out all the parts, it took me less than 15 minutes to install both sides. It's crucial to ensure you order the correct style for your vehicle, whether it's New or Classic.
I am highly satisfied with my purchase and will certainly consider ordering from YITAMOTOR again in the future. I will definitely order again and recommend it to my brother and friends.
chri5k
USA
Diesel
So is this Yitamotors pretending to be a customer of Yitamotors to recommend Yitamotors?
markabby
Monticello, Kentucky
2020 Limited
hey..as i always tell my wife: "real men don't read instructions"
(then i always have to go back and read them)
Units
Ms
2023 Bighorn
6.7l Cummins
I have that same conversation with my wife, lol. But, when I “eventually” have to take a peek at the instructions, I try not to do it in front of her so I don’t have to hear I told you so.
Nikipowpez
Newbie here. I just installed running boards I got from Amazon and there were minimal instructions. They looked like they didn't line up at first, the center bolts were about 2 inches off. Then we realized we had them on the wrong sides. They looked the same but there was a right and left. After we put them on the correct sides, they were perfect.
Glowz
