Running Cut out back to tailpipes
SportyJames
Corpus Christi
2015 RAM 1500 Sport
Anyone ever run a pipe from the cut out to the back of muffler to the two tailpipes I am curious of the sound if I do this.
quietpeen
2021 TRX
Hellcat
My guess would be the same as straight pipes because that's all you would really be doing.
02ramboi
live oak florida
4.7 v8
It will be a little raspy but if you like it loud that's what it will be
4.7 v8
Hi flow cat/flowmaster exhaust
7 inch lift/5 inch lift
20 inch falken wildpeak at3/33's
quietpeen
2021 TRX
Hellcat
mufflex makes a muffler delete, sounds like you want to bypass the muffler all together.
SportyJames
SportyJames
Corpus Christi
2015 RAM 1500 Sport
No, I have to keep the stock muffler (for the wife and when I have clients in the truck)
I just want to move the exhaust sound from underneath the cab and put it out the back from the cut out.
WilliamS
Tampa FL
If Im understand you want to have a cutout, pipe it around the mufflers, then back into the stock pipes? Im sure you can, but man that is a lot of plumbing.
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
I have seen it done before. Running stock resonators also will help with rasp. Or maybe just running resonated tips.
Kmiko
