Rust Proofing ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
2015 Quad Cab!
Just curious on if after market rustproofing is needed or is it done at the factory! Thanks
If your in a snow state you may want to spray fluid film on, or similar.
02Steve15
Connecticut
Power wash it once a week/once cleanup is done after each snowfall. Save a few $.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks, Fluid film will be done in a few weeks,, I was curious if the factory rustproofs the rockers etc like back in the day when you really did not need to Zeibart your car/truck
2015HD
Maine
IMO you would be better off going with LPS 3, I just did mine last week. I did lots of reading on FF v. LPS 3 and found a couple of tests people did with similar results. Here is one I bookmarked:
Protective spray??? - Page 2
The main issue for me is that FF will wash off, LPS 3 will not. The crap they use on the Maine roads is so nasty I hit the car wash weekly, FF would not last long on my truck. LPS 3 (according to what I've read) should last 2-3 years. I got mine on eBay from a vendor called Zoro.
If you go with LPS 3 make sure the product is warm when applied, do in a heated garage with some ventilation and wear gloves. It's basically a wax coating (when dry) and cleanup requires a solvent.
Good luck!
That stuff looks better.
THETANK
up jor *** mang
2015 R/T
I do not drive mine in the winter or summer if rain is in the forecast so I do not need rustproofing service, if I did drive in the winter I would use Krown personally, great stuff. Good luck.
joshhhh
