Rusted Rear Fender.
RoadKing
Ga
2022 Bighorn
HEMI 5.7
A friend of mine posted pictures of his new RAM on Facebook and one of his friends warned him about fenders rusting out blah blah blah maybe it’s true. This is what he said
“Get to a body expert now, while its new. Ask about rusted out rear renders and what you can do about it. Dodge and their foam filler...”
Whats he talking about Foam Filler? ...anybody know?
Thanks!
fire101fighter
South Jersey
No idea but my 10 has about a 2 quarter size spot on the driver side rear fender, hasn’t broken through yet and there is no other rust on the truck at all.
Jeepwalker
WI
2012 Reg Cab, 4x4
What year ram does he have?
RoadKing
RoadKing
Ga
2022 Bighorn
HEMI 5.7
Uncertain what year Rams the guy was referring to but my buddy just bought a 2017. I did see a Ram 1500 today that was not a gen 4 maybe 3 I guess. Right above center wheel well on the rear there were to fist size corrosion spots with multiple bubbles under the paint.
Is rust through not warranted?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
All makes rust, its steel and they use salt on the roads its going to happen.
WaterBoy1
Ontario
2014 Laramie CC2500 Black Edition
I get all my vehicles Krown rustproofed every year. It's cheap insurance, and I've never had a vehicle rust out on me that I did this to.
Sent from my SM-G950W using Tapatalk
patchelect
Dalton, MA
My understanding is that RAM/Dodge used a sandwich method on the vehicles that included some sort of sealant/bonding product that collected all the crud. Over time the Gen III's will show signs of rust, probably even trucks that never saw road salt. I understand the Gen IV was when they changed the method of assembly and the rusting issues was pretty much resolved. I keep my eye out for 4th Gen trucks with rust and while fire101fighter is experiencing issues, I haven't really noticed any other trucks with problems, unless they were obviously driven hard and put away wet. I would assume that if you are in a high road salt area you will be more likely to experience problems than a vehicle in Arizona, but that was always true.
blackbeautyhemi
Lewistown, PA
I’m guessing he has the 3rd gen in mind with the rusting rear fender wells. Tail gates also. People get too stuck in the past with things like that.
demort71
Illinois
He is referring to the rust issue that Rams have in geographical areas that have climates with higher humidity like the Midwest, East Coast. This issue may have been resolved on the latest Rams.
The worst problem area was above the wheel openings on the bed. The rest of the truck seem to have less chance of rust. Tailgates have always been a problem for truck manufacturers. With the light gauge steel used on car and truck bodies today, a scratch or loss of paint can turn into a rust hole in a couple of years on any vehicle. So if you scratch the paint to the bare metal, you are asking for trouble.
On the Gen II and III model Rams, the area above the wheel opening has foam material sandwiched between the wheel housing and bed side. The foam traps moisture in it. Moisture can come off the road via the rear wheels or even just from the air. Spot welds in this area are not protected from moisture and are left bare by the factory. That is where it usually rusts, on these spot welds and then spreads over time.
I bought a '04 Rumble Bee Ram 1500 two months ago. Nice looking truck with the black plastic wheel opening protectors on it! If you look under the protectors you can see the rust-though. Rest of truck is pretty sharp.
Two years ago I fixed a 06 Dakota with the same rust issue, in the same area, myself. After cutting the damaged area out, I found the foam that had trapped the moisture. The truck had spent most of its life in North Carolina, yet it was also rusted. They don't get snow or salted roads there.
On the Bee, I am going to have to replace the sheet metal in the rusted out area. Don't waste your time with just bondo and new paint. That cover up will last about six to nine months. Cut out the rusted area and replace it with a new metal patch panel. Or you can replace the whole bed side! One estimate of the latter to fix the bed was about $4000 for both sides at a local body shop.
There is also some rust in the cab corners. The cab corners damage was likely caused by no epoxy enamel reaching the backside of the cab corners at the factory, hence it left the factory as bare metal on the back side and eventually rusted. The solution is to replace the cab corner.
I am restoring the body of a 1978 Lil Red Express pickup. It was stored inside since 1990 and kept clean and dry afterwards. The only places it had rusted out were areas that were not rust proofed with the factory epoxy enamel primer sealer. The factory just couldn't spray it into a few tight hidden areas due to paint and assembly processes used at that assembly plant in that time. Eventually moisture attacked the metal and it rusted from the inside out. There were two areas of rust-the inside front corner of one door and the bottom of one fender between the outside steel and the frame piece that was behind it that adds strength. The other original fender and door were not rusted!
So that is what happened on the 04 Rumble Bee's cab corners-no primer. The corners had been covered up and protected from rock chips by the truck's ground effects package that has since been removed. I decided to protect the Bee and preserve it for future Ram collectors.
The same rust issues (but to a much greater extent) occurred on 1973 and up Chevy and to a lesser extent on Ford trucks. GM used Japanese steel in that period, that had been washed with salt water after it was milled. Fresh water is expensive in Japan. The salt was never rinsed off before the steel was made into body panels by GM. Those panels rusted from the inside out. I detailed used cars and trucks in the 70s and I couldn't understand why vehicles that had been Z-barted had huge holes in them when the truck was only a four or five years old! That's why you seldom see Chevy trucks made in the 70s! They rusted away literally!
I hope that Ram did finally eliminate the rust out issues on the latest generation of its pickups. These are good trucks IMO mechanically and electronically. It's silly to continue building them to rust out in specific areas when its an easy manufacturing and engineering fix.
