Cost of a rear sliding window?
RamDiver
Marlborough, Ontario Canada
2021 DS
My 23 had a drip in the upper right corner I discovered while washing it one day. Rather than screw with the dealer I found some rubber weatherstripping at Lowe’s that could be pressed into the cavity all across the top of the window and so far that has sealed it up fine. It’s a double tube weatherstrip that I cut down the center and then pressed down into the cavity across the top with a popcycle stick, out of view.
That looks like a great idea.
Could you post a close-up pic of the window with the weatherstripping installed?
Marshall
Sk, Canada
2014 sport
I could see that coming :D .
I would think that frames should be covered same as the rest of the truck, glass breakage would not of coarse.
phorrestphire
