RV275 Injectors
scippy
Jackson, N.J.
2001 3500 dually
24v cummins
With the Edge EZ installed in my truck and stock turbo (aside from my 4" turbo back & DDPP Fass) would the RV275 sticks maximize my gains in "towing" performance?......or, would VP7X9 injectors be a better suit for towing?.....Also, would the 100hp injectors run my EGT's too high for comfort?
DodgeTx
SEGUIN
5.9L Cummins, 5.2l v8
may be better to post in the specific cummins forum, I don't know the answer and am new to cummins but would love to find out!
jlbayes
2001 & 1997
5.9l cummins
Depends on how you drive really. Injectors are a balancing act with the turbocharger.
scippy
scippy
Jackson, N.J.
2001 3500 dually
24v cummins
I'm a lot older now and don't get my foot into it like I would years ago, (not that you'd hate to get stuck behind me on a one lane road lol)
but, can I mix 100 hp sticks with stock turbo haulin' 14k worth of boat & trailer ..........I guess the balancing act would be monitoring EGT
jlbayes
2001 & 1997
5.9l cummins
Being as this truck has a hy35 I would not. If it was an hx35 I would say go for it.
scippy
scippy
Jackson, N.J.
2001 3500 dually
24v cummins
OK stock hy35 won't cut it, but hx35 for 100hp injectors would.........so for stock turbo hy35 what would be (in your opinion) the max?....rv275's ??
jlbayes
2001 & 1997
5.9l cummins
With the edge ez, yes.
scippy
scippy
Jackson, N.J.
2001 3500 dually
24v cummins
So I ordered the Bosch RV2-75 Injectors....I was thinking of installing them myself (not a wrencher, but mechanically inclined) what degree of difficulty would you say to install?
from 1 to 10 ???.............Thnx, Scippy
jlbayes
2001 & 1997
5.9l cummins
3 or 4. Takes me about an hour to do them. 2 to 3 hours for a first timer. Make sure to get new connector tube orings as well. I pull the lines off the pump as it is easier than trying to fight them and the connector tubes. The lines come off in two 3 piece sets.
scippy
scippy
Jackson, N.J.
2001 3500 dually
24v cummins
OK, thanks! ......How about replacing the injector tubes (you call them connector tubes same thing right?) Should I replace them since they'll be out
anyway when I'm installing new injectors?.......found some new ones on e-bay.
jlbayes
2001 & 1997
5.9l cummins
I would not buy them from ebay. They are likely to be China crap cast. I have not had to ever replace mine but they were always in great shape.
scippy
scippy
Jackson, N.J.
2001 3500 dually
24v cummins
Yea, If I have to replace I'll go with genuine Bosch tubes there not much more then the ones on e-bay.
